Saltar al contenido principal
Munchkinz LCD Assembly
Qué necesitas
  1. Munchkinz LCD Assembly, Opening Device: paso 1, imagen 1 de 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz LCD Assembly, Pry Device Apart: paso 2, imagen 1 de 2 Munchkinz LCD Assembly, Pry Device Apart: paso 2, imagen 2 de 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz LCD Assembly, Separated Device: paso 3, imagen 1 de 1
    • After prying the device apart, it should look like this.
  4. Munchkinz LCD Assembly, Remove Speaker: paso 4, imagen 1 de 1
    • Use the plastic opening tool to remove the speaker from the casing.
  5. Munchkinz LCD Assembly, Pry Camera: paso 5, imagen 1 de 1
    • Use the slim plastic opening tool to pry the camera from its position.
  6. Munchkinz LCD Assembly, Unscrew Volume Module: paso 6, imagen 1 de 2 Munchkinz LCD Assembly, Unscrew Volume Module: paso 6, imagen 2 de 2
    • Unscrew the two screws that hold the volume module to the casing.
  7. Munchkinz LCD Assembly, Pry Battery: paso 7, imagen 1 de 1
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  8. Munchkinz LCD Assembly, Remove Ribbons: paso 8, imagen 1 de 1
    • Remove the two highlighted ribbons from the motherboard.
  9. Munchkinz LCD Assembly, Remove Screws: paso 9, imagen 1 de 1
    • Use the screw driver to remove the highlighted screws.
  10. Munchkinz LCD Assembly, Remove Hidden Screw: paso 10, imagen 1 de 1
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
  11. Munchkinz LCD Assembly, Remove Motherboard: paso 11, imagen 1 de 1
    • Remove the motherboard from the casing.
  12. Munchkinz LCD Assembly, Pry Up Screen: paso 12, imagen 1 de 3 Munchkinz LCD Assembly, Pry Up Screen: paso 12, imagen 2 de 3 Munchkinz LCD Assembly, Pry Up Screen: paso 12, imagen 3 de 3
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
  13. Munchkinz LCD Assembly, Solder LCD Wires: paso 13, imagen 1 de 1
    • Unsolder the black and red LCD wires.
Conclusión
Una persona más ha completado esta guía.
David Wood
Miembro Desde 02/05/15
440 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team 3-6, Rose Winter 2015 Miembro de UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 344
