Introducción
If your screen is not working properly follow this guide to replace it.
Qué necesitas
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Unscrew the two screws that hold the volume module to the casing.
Use the plastic opening tool to hold the camera ribbon back.
Unscrew the screw under ribbon with the screw driver.
Oriented the device so the battery is closest to the user.
Use the plastic opening tool to pry the clips up to release LCD screen.
Gently lift the northern end of the screen and slide it out horizontally.
Una persona más ha completado esta guía.
