Saltar al contenido principal
Munchkinz Battery Replacement
Qué necesitas
  1. Munchkinz Battery Replacement, Opening Device: paso 1, imagen 1 de 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Battery Replacement, Pry Device Apart: paso 2, imagen 1 de 2 Munchkinz Battery Replacement, Pry Device Apart: paso 2, imagen 2 de 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Battery Replacement, Separated Device: paso 3, imagen 1 de 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Battery Replacement, Removing battery: paso 4, imagen 1 de 3 Munchkinz Battery Replacement, Removing battery: paso 4, imagen 2 de 3 Munchkinz Battery Replacement, Removing battery: paso 4, imagen 3 de 3
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  5. Munchkinz Battery Replacement, Remove battery completely: paso 5, imagen 1 de 1
    • Use the Soldering Iron to disconnect the each cable.
Conclusión
Hee Jin Cho
Miembro Desde 01/14/15
113 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 3-6, Rose Winter 2015 Miembro de UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 507
