Introducción
Outline what you are going to teach someone how to do.
Qué necesitas
Remove twenty-four 6 mm Phillips #2 from all 6 sides.
Once the screws are removed, gently pull apart the frame.
Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up.
Use the Jimmy to remove the glue connecting the motherboard to the white frame.
Una persona más ha completado esta guía.
