Saltar al contenido principal
Mt. Fury Roadmaster Brake Pad Replacement
Qué necesitas
  1. Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: paso 1, imagen 1 de 2 Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: paso 1, imagen 2 de 2
    • Locate and remove the dome nut with a 10mm open-end wrench.
  2. Mt. Fury Roadmaster Brake Pad Replacement: paso 2, imagen 1 de 1
    • Inspect brake pad for wear.
  3. Mt. Fury Roadmaster Brake Pad Replacement: paso 3, imagen 1 de 1
    • Dome nut (left), lock washer (middle), and brake pad (right).
    • Be sure to save the dome nut and lock washer just in case the replacement brake shoe does not include them.
    • When installing the new brake shoe, make sure it is properly aligned so it is in full contact with the edge of the rim.
Conclusión
To install your new brake shoes, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Monty Dodge Jr
Miembro Desde 01/22/14
669 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 1-40, Maness Winter 2014 Miembro de Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 2,045
