Saltar al contenido principal
Mr. Coffee TF6 Power Cord Replacement
Qué necesitas
  1. Mr. Coffee TF6 Power Cord Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Mr. Coffee TF6 Power Cord Replacement: paso 2, imagen 1 de 2 Mr. Coffee TF6 Power Cord Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Mr. Coffee TF6 Power Cord Replacement: paso 3, imagen 1 de 1
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Mr. Coffee TF6 Power Cord Replacement, Power Cord: paso 4, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
  5. Mr. Coffee TF6 Power Cord Replacement: paso 5, imagen 1 de 1
    • Carefully lift the wire harness from the base of the TF6, detaching it completely.
    • The power cord wiring is now completely accessible.
  6. Mr. Coffee TF6 Power Cord Replacement: paso 6, imagen 1 de 2 Mr. Coffee TF6 Power Cord Replacement: paso 6, imagen 2 de 2
    • Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split.
  7. Mr. Coffee TF6 Power Cord Replacement: paso 7, imagen 1 de 2 Mr. Coffee TF6 Power Cord Replacement: paso 7, imagen 2 de 2
    • Using your fingers, pry the heatshrink off from the power cord leads.
  8. Mr. Coffee TF6 Power Cord Replacement: paso 8, imagen 1 de 1
    • Using a 14-16 AWG wire stripper, strip the leads on the replacement power cord.
  9. Mr. Coffee TF6 Power Cord Replacement: paso 9, imagen 1 de 1
    • Solder the power cord's positive lead to the white nylon wire.
    • Solder the power cord's ground lead to the bronze nylon wire.
    • Ensure the correct leads are being soldered together (power to power, ground to ground). Soldering the incorrect leads together will result in hazardous conditions for both the TF6 and the user when the unit is powered on.
    • Consult the replacement power cord's user manual, packaging, or manufacturer in order to verify the power and ground leads.
Conclusión
Andrew
Miembro Desde 01/24/14
116 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-18, Regan Winter 2014 Miembro de Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 Miembros
5 Guías creadas
Un comentario
Excellent! very helpful...
NP Designs 123 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 718
