Saltar al contenido principal
Mr. Coffee TF6 Internal Water Tubes Replacement
Qué necesitas
  1. Mr. Coffee TF6 Internal Water Tubes Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Mr. Coffee TF6 Internal Water Tubes Replacement: paso 2, imagen 1 de 2 Mr. Coffee TF6 Internal Water Tubes Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Mr. Coffee TF6 Internal Water Tubes Replacement: paso 3, imagen 1 de 1
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Mr. Coffee TF6 Internal Water Tubes Replacement, Internal Water Tubes: paso 4, imagen 1 de 1
    • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
  5. Mr. Coffee TF6 Internal Water Tubes Replacement: paso 5, imagen 1 de 1
    • Carefully pull the silicon tubing off of the metal tubing.
  6. Mr. Coffee TF6 Internal Water Tubes Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
  7. Mr. Coffee TF6 Internal Water Tubes Replacement: paso 7, imagen 1 de 1
    • Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
    • If all screws have been removed and the tubes have been detached, the assemblies should separate easily.
  8. Mr. Coffee TF6 Internal Water Tubes Replacement: paso 8, imagen 1 de 1
    • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
  9. Mr. Coffee TF6 Internal Water Tubes Replacement: paso 9, imagen 1 de 1
    • Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
Conclusión
Una persona más ha completado esta guía.
Jordan
Miembro Desde 01/31/14
204 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-18, Regan Winter 2014 Miembro de Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,643
