Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Mr. Coffee DW13 Power Cord Replacement
Qué necesitas
  1. Mr. Coffee DW13 Power Cord Replacement, Base: paso 1, imagen 1 de 2 Mr. Coffee DW13 Power Cord Replacement, Base: paso 1, imagen 2 de 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Power Cord Replacement: paso 2, imagen 1 de 2 Mr. Coffee DW13 Power Cord Replacement: paso 2, imagen 2 de 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Power Cord Replacement: paso 3, imagen 1 de 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Power Cord Replacement, Power Cord: paso 4, imagen 1 de 2 Mr. Coffee DW13 Power Cord Replacement, Power Cord: paso 4, imagen 2 de 2
    • Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
    • Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
  5. Mr. Coffee DW13 Power Cord Replacement: paso 5, imagen 1 de 2 Mr. Coffee DW13 Power Cord Replacement: paso 5, imagen 2 de 2
    • Gently lift up on the white tab, removing it from the coffee machine.
  6. Mr. Coffee DW13 Power Cord Replacement: paso 6, imagen 1 de 2 Mr. Coffee DW13 Power Cord Replacement: paso 6, imagen 2 de 2
    • Locate the 2 electrical connectors running from the black plastic-coated power cord to the interior of the power switch.
    • One cord is copper colored and ends at the power switch in a silver metal square.
    • The other cord is white and ends at the power switch in a black plastic square.
  7. Mr. Coffee DW13 Power Cord Replacement: paso 7, imagen 1 de 2 Mr. Coffee DW13 Power Cord Replacement: paso 7, imagen 2 de 2
    • Grasp the copper cord close to the power switch. Lightly pull the silver end tab from the end to detach it.
  8. Mr. Coffee DW13 Power Cord Replacement: paso 8, imagen 1 de 2 Mr. Coffee DW13 Power Cord Replacement: paso 8, imagen 2 de 2
    • Lightly pull the white cord away from the power switch by grasping the black plastic-coated head.
    • There are two white cords attached to each other. Pull them apart by grasping the different black heads and separating them.
  9. Mr. Coffee DW13 Power Cord Replacement: paso 9, imagen 1 de 3 Mr. Coffee DW13 Power Cord Replacement: paso 9, imagen 2 de 3 Mr. Coffee DW13 Power Cord Replacement: paso 9, imagen 3 de 3
    • Pull the power cord through the hole at the back of the base of the machine, followed by the two colored cords.
Conclusión
3 personas más completaron esta guía.
Tess Bradley
Miembro Desde 01/26/14
388 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-31, Maness Winter 2014 Miembro de Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
Miembros de 4
13 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 3,605
