Saltar al contenido principal
Mr. Coffee DW13 O Ring Replacement
Qué necesitas
  1. Mr. Coffee DW13 O Ring Replacement, Base: paso 1, imagen 1 de 2 Mr. Coffee DW13 O Ring Replacement, Base: paso 1, imagen 2 de 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 O Ring Replacement: paso 2, imagen 1 de 2 Mr. Coffee DW13 O Ring Replacement: paso 2, imagen 2 de 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 O Ring Replacement: paso 3, imagen 1 de 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 O Ring Replacement, O Ring: paso 4, imagen 1 de 2 Mr. Coffee DW13 O Ring Replacement, O Ring: paso 4, imagen 2 de 2
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
  5. Mr. Coffee DW13 O Ring Replacement: paso 5, imagen 1 de 1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  6. Mr. Coffee DW13 O Ring Replacement: paso 6, imagen 1 de 2 Mr. Coffee DW13 O Ring Replacement: paso 6, imagen 2 de 2
    • Use needle-nose pilers to pinch and loosen the crimps
  7. Mr. Coffee DW13 O Ring Replacement: paso 7, imagen 1 de 1
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 O Ring Replacement: paso 8, imagen 1 de 2 Mr. Coffee DW13 O Ring Replacement: paso 8, imagen 2 de 2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  9. Mr. Coffee DW13 O Ring Replacement: paso 9, imagen 1 de 2 Mr. Coffee DW13 O Ring Replacement: paso 9, imagen 2 de 2
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
  10. Mr. Coffee DW13 O Ring Replacement: paso 10, imagen 1 de 2 Mr. Coffee DW13 O Ring Replacement: paso 10, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 10-31, Maness Winter 2014 Miembro de Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,018
