Saltar al contenido principal
Mr. Coffee BVMC-SJX33GT Valve Replacement
Qué necesitas
  1. Mr. Coffee BVMC-SJX33GT Valve Replacement, Base: paso 1, imagen 1 de 1
    • Turn your coffee maker over so that the base is facing up.
  2. Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 2, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 2, imagen 2 de 2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
  3. Mr. Coffee BVMC-SJX33GT Valve Replacement, security screws: paso 3, imagen 1 de 1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
  4. Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 4, imagen 1 de 1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
  5. Mr. Coffee BVMC-SJX33GT Valve Replacement, Rubber Hose: paso 5, imagen 1 de 3 Mr. Coffee BVMC-SJX33GT Valve Replacement, Rubber Hose: paso 5, imagen 2 de 3 Mr. Coffee BVMC-SJX33GT Valve Replacement, Rubber Hose: paso 5, imagen 3 de 3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
  6. Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 6, imagen 1 de 3 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 6, imagen 2 de 3 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 6, imagen 3 de 3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
  7. Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 7, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 7, imagen 2 de 2
    • Slide metal clamps off hoses.
  8. Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 8, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 8, imagen 2 de 2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
  9. Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 9, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 9, imagen 2 de 2
    • Grip the hoses and pull them straight up and out.
  10. Mr. Coffee BVMC-SJX33GT Valve Replacement, Valve: paso 10, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT Valve Replacement, Valve: paso 10, imagen 2 de 2
    • After pulling the second tube out, locate the bulging part of the hose that indicates the valve's placement.
  11. Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 11, imagen 1 de 3 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 11, imagen 2 de 3 Mr. Coffee BVMC-SJX33GT Valve Replacement: paso 11, imagen 3 de 3
    • Grip the tube and push the valve out the end of the hose.
    • Remember the direction of the valve when you pull it out because this valve is one way. If you insert it or reinsert it the wrong way, water will not flow through the coffee maker.
Conclusión
15 personas más completaron esta guía.
Mackenzie Aiken
Miembro Desde 01/27/15
1,473 Reputación
6 Guías creadas
Equipo
21 comentarios
Thank you. Beautiful in it's clarity and simplicity. The attention to detail with specific regard to the size of bolts and tools needed moved me. Too much? Maybe a little. Thank you anyway.
jdwolf1282 - Contestar
Thank you. Very well done. Do you know if I can buy a replacement valve?
Scott - Contestar
Unfortunately no. Because a lot of things are built with planned obsolescence in mind, it's very difficult to find parts. I would check thrift stores for same brand cheap coffee makers that might have similar equipment.
Mackenzie Aiken -
I have a similar model and the valve sticks at odd times...it brews half the pot and steams the rest of the water. I have cleaned, drilled the hole slightly larger that the ball seals in...with no solution! Will it it thermally pump water without the ball in the valve? Thanks!
elronhubbard - Contestar
Well firstly make sure the valve is pointing the right direction in the rubber tubing. As for your question about pumping water, that I can't answer. Try soaking the valve in alcohol then warm soapy water, there may be residue from the grinds on the ball causing it to stick.
Your best course of action might be to go to a thrift store and look for a similar model by Mr. Coffee and simply replace the valve. Drilling the hole initially might have thwarted additional attempts to make this valve work.
Mackenzie Aiken -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 67
Ultimos 30 días: 234
Todo El Tiempo: 63,583
