Saltar al contenido principal
Mr. Coffee BVMC-SJX33GT O-Rings Replacement
Qué necesitas
  1. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Base: paso 1, imagen 1 de 1
    • Turn your coffee maker over so that the base is facing up.
  2. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 2, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 2, imagen 2 de 2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
  3. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, security screws: paso 3, imagen 1 de 1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
  4. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 4, imagen 1 de 1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
  5. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: paso 5, imagen 1 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: paso 5, imagen 2 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: paso 5, imagen 3 de 3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
  6. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 6, imagen 1 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 6, imagen 2 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 6, imagen 3 de 3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
  7. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 7, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 7, imagen 2 de 2
    • Slide metal clamps off hoses.
  8. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 8, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 8, imagen 2 de 2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
  9. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 9, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 9, imagen 2 de 2
    • Grip the hoses and pull them straight up and out.
  10. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: paso 10, imagen 1 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: paso 10, imagen 2 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: paso 10, imagen 3 de 3
    • Locate the two 17mm screws securing the bracing bar.
    • Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
  11. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 11, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 11, imagen 2 de 2
    • Using a finger to keep the heating plate in place, grip the metal tubing and gently pull it away from the plate.
    • Set the metal tubing aside.
  12. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 12, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 12, imagen 2 de 2
    • Push the heating plate up from below and remove.
  13. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: paso 13, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: paso 13, imagen 2 de 2
    • Locate the five 11.5mm screws securing the plastic ring to the coffee maker.
    • Unscrew the screws using a #2 Phillip's head screwdriver.
  14. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 14, imagen 1 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 14, imagen 2 de 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 14, imagen 3 de 3
    • Using a plastic opening tool, pry the first o-ring out of the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thicker than the second.
  15. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 15, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 15, imagen 2 de 2
    • Gripping the plastic ring, pull it free from the coffee maker.
    • Flip the plastic ring over.
  16. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 16, imagen 1 de 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: paso 16, imagen 2 de 2
    • Using your fingers, pry the other o-ring free from the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thinner than the first.
Conclusión
Una persona más ha completado esta guía.
Mackenzie Aiken
Miembro Desde 01/27/15
1,473 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 2,429
