Introducción
This guide is for those looking to replace their brake lever assembly on a mountain bike. It is a fairly simple task that does not require much prior bike knowledge. It only requires a 5mm Allen key, the lever assembly, isopropyl alcohol, and the bike.
Qué necesitas
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
Una persona más ha completado esta guía.
