Saltar al contenido principal
Moultrie I45 GameSpy Buttons Replacement
Qué necesitas
  1. Moultrie I45 GameSpy Buttons Replacement, Casing: paso 1, imagen 1 de 1
    • Using a Philips head screwdriver, remove the eight 6mm screws located at the bottom of the device.
  2. Moultrie I45 GameSpy Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the butterfly nut from the lid arm.
  3. Moultrie I45 GameSpy Buttons Replacement: paso 3, imagen 1 de 1
    • Remove the lid-covering.
  4. Moultrie I45 GameSpy Buttons Replacement: paso 4, imagen 1 de 1
    • Using a Phillips head screwdriver, remove the six 4mm screws from the face of the camera.
  5. Moultrie I45 GameSpy Buttons Replacement: paso 5, imagen 1 de 1
    • Gently separate the two halves of the case.
    • The two halves are connected by a wire. Pulling too roughly can damage the wires and cause the camera to stop functioning.
  6. Moultrie I45 GameSpy Buttons Replacement, Buttons: paso 6, imagen 1 de 1
    • Using a Phillips head screwdriver, remove the twelve 3mm screws from the circuit board.
  7. Moultrie I45 GameSpy Buttons Replacement: paso 7, imagen 1 de 1
    • Gently remove the circuit board from the face of the camera.
  8. Moultrie I45 GameSpy Buttons Replacement: paso 8, imagen 1 de 1
    • Remove the buttons.
Conclusión
Sean Hill
Miembro Desde 01/29/15
458 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team 3-7, Rose Winter 2015 Miembro de UW Tacoma, Team 3-7, Rose Winter 2015
UWT-ROSE-W15S3G7
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 374
