Saltar al contenido principal
Motorola syn1654A Headphone Speaker Replacement
Qué necesitas
  1. Motorola syn1654A Headphone Speaker Replacement, Headphone Speaker: paso 1, imagen 1 de 1
    • Make sure the headphones are off and unplugged from any devices.
    • Remove leather headphone cushion by pulling edge towards middle of headphone.
    • It should slip off the device.
  2. Motorola syn1654A Headphone Speaker Replacement: paso 2, imagen 1 de 1
    • Carefully peel back foam pad to prevent tearing.
    • It is glued at both the top and bottom.
  3. Motorola syn1654A Headphone Speaker Replacement: paso 3, imagen 1 de 1
    • Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • To avoid stripping screws, be sure to use the right screw bit oriented perpendicular to the face of the screw.
  4. Motorola syn1654A Headphone Speaker Replacement: paso 4, imagen 1 de 1
    • With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • Solder wires onto corresponding pads of replacement speaker.
    • For soldering see the ifixit soldering guide: Cómo soldar y desoldar conexiones
Conclusión
John Ware
Miembro Desde 02/24/14
325 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 398
