Saltar al contenido principal
Motorola i90c speaker replacement
Qué necesitas
  1. Motorola i90c speaker replacement, Battery: paso 1, imagen 1 de 3 Motorola i90c speaker replacement, Battery: paso 1, imagen 2 de 3 Motorola i90c speaker replacement, Battery: paso 1, imagen 3 de 3
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Motorola i90c speaker replacement: paso 2, imagen 1 de 3 Motorola i90c speaker replacement: paso 2, imagen 2 de 3 Motorola i90c speaker replacement: paso 2, imagen 3 de 3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Motorola i90c speaker replacement, Antenna: paso 3, imagen 1 de 2 Motorola i90c speaker replacement, Antenna: paso 3, imagen 2 de 2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Motorola i90c speaker replacement, Disassembling Motorola i90c Internal Backplate: paso 4, imagen 1 de 3 Motorola i90c speaker replacement, Disassembling Motorola i90c Internal Backplate: paso 4, imagen 2 de 3 Motorola i90c speaker replacement, Disassembling Motorola i90c Internal Backplate: paso 4, imagen 3 de 3
    • Unscrew the 3 screws shown.
    • Lift up the right part of the Nextel logo and unscrew the screw underneath.
  5. Motorola i90c speaker replacement: paso 5, imagen 1 de 2 Motorola i90c speaker replacement: paso 5, imagen 2 de 2
    • DO NOT force the cover off as it could damage the ribbon cable!
    • Gently lift the back cover off.
  6. Motorola i90c speaker replacement: paso 6, imagen 1 de 3 Motorola i90c speaker replacement: paso 6, imagen 2 de 3 Motorola i90c speaker replacement: paso 6, imagen 3 de 3
    • Carefully pry off the connection between the headphone jack and logic board.
  7. Motorola i90c speaker replacement, Speaker System: paso 7, imagen 1 de 3 Motorola i90c speaker replacement, Speaker System: paso 7, imagen 2 de 3 Motorola i90c speaker replacement, Speaker System: paso 7, imagen 3 de 3
    • Use the prying tools to wedge out the circular part of the speaker system.
    • Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
Conclusión
Jorge
Miembro Desde 04/14/10
4 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 29-61, Johann Spring 2010 Miembro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,179
