Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
Replace the SIM card in your i850!
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Use your thumb to slide the back cover locker away from the antenna.
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Slide the back cover towards the antenna while lifting the cover away from the phone. Slide the back cover towards the antenna while lifting the cover away from the phone.
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Lift the battery out of the phone while pushing it towards the antenna. Lift the battery out of the phone while pushing it towards the antenna.
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Place thumb on SIM Card door latch.
    • Place thumb on SIM Card door latch.
  6. Slide the SIM Card door latch away from the SIM Card. The door should pop open. If it does not pop open, use a fingernail to open it.
    • Slide the SIM Card door latch away from the SIM Card. The door should pop open. If it does not pop open, use a fingernail to open it.
  7. Lift the SIM Card with your thumb and forefinger to complete the removal of the SIM card!
    • Lift the SIM Card with your thumb and forefinger to complete the removal of the SIM card!
Conclusión
Alex Jones
Miembro Desde 09/04/10
1 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 34-56, Forte Spring 2010 Miembro de Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 4,392
