Saltar al contenido principal
Introducción
Replacement of malfunctioning LCD screen.
  1. Open the flip cover of the phone with the LCD screen facing towards you.
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Use a Razor Blade to remove the screw covers. Razor Blade is very sharp. Use caution.
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Unscrew the screws using a Phillips #00 Screwdriver.
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Partially close the flip cover of the phone in order to take off the outer case.
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Completely remove the outer casing from the phone.
    • Completely remove the outer casing from the phone.
  8. Place your thumb underneath the protective metal covering to remove it from the phone. Place your thumb underneath the protective metal covering to remove it from the phone.
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Gently detach the black microchip from the phone with a Tweezer.
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Prop out the LCD board from the phone using your fingertips.
    • Prop out the LCD board from the phone using your fingertips.
  11. Remove the LCD board from the phone by grabbing the bottom side of the LCD board. Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Firmly detach the gold strip using a Tweezer.
    • Firmly detach the gold strip using a Tweezer.
  13. Prop out the LCD screen using a Small Flathead Screwdriver.
    • Prop out the LCD screen using a Small Flathead Screwdriver.
  14. Remove the LCD screen from the LCD board. Remove the LCD screen from the LCD board. Remove the LCD screen from the LCD board.
    • Remove the LCD screen from the LCD board.
Conclusión
Andrew Aw
Miembro Desde 08/04/10
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 34-56, Forte Spring 2010 Miembro de Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,045
