Saltar al contenido principal
Motorola i710 Microphone Replacement
Qué necesitas
  1. Motorola i710 Microphone Replacement, Battery Cover: paso 1, imagen 1 de 2 Motorola i710 Microphone Replacement, Battery Cover: paso 1, imagen 2 de 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Microphone Replacement, Battery: paso 2, imagen 1 de 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Microphone Replacement, Back Casing: paso 3, imagen 1 de 3 Motorola i710 Microphone Replacement, Back Casing: paso 3, imagen 2 de 3 Motorola i710 Microphone Replacement, Back Casing: paso 3, imagen 3 de 3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Motorola i710 Microphone Replacement, Microphone: paso 4, imagen 1 de 3 Motorola i710 Microphone Replacement, Microphone: paso 4, imagen 2 de 3 Motorola i710 Microphone Replacement, Microphone: paso 4, imagen 3 de 3
    • Lift the circuit board away from the case of the phone, being careful not to break the wire that goes up into the hinge. This will give you access to the microphone.
    • The microphone sits just below the keys on the front cover molding.
    • Grasp the microphone with tweezers and lift it out of the front cover.
Conclusión
Carson Meena
Miembro Desde 10/22/12
16 Reputación
5 Guías creadas
Equipo
Clemson, Team 14-2, Benson Fall 2012 Miembro de Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 11
Todo El Tiempo: 292
