Introducción
Once the LCD Screen Cover has been removed, the LCD Screen can be accessed as shown in this guide.
Partes
No se requieren partes.
  1. Slide the cover release button towards the bottom of the phone Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Push the battery towards the top of the phone and lift up.
    • Push the battery towards the top of the phone and lift up.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen. With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone. The four screws holding the upper half of the phone together should now be visible.
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  5. With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone. Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  6. Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary. The LCD screen should now be completely separated from the phone. The LCD screen should now be completely separated from the phone.
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
  7. Use a spudger to detach the ribbon cable connecting the the LCD Screen to the rest of the phone. The LCD Scren will now lift out from the phone casing. Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
    • Use a spudger to detach the ribbon cable connecting the the LCD Screen to the rest of the phone.
    • The LCD Scren will now lift out from the phone casing.
    • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
Conclusión
Una persona más ha completado esta guía.
Carson Meena
Miembro Desde 22/10/12
16 Reputación
5 Guías creadas
Equipo
Clemson, Team 14-2, Benson Fall 2012 Miembro de Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Miembros
17 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 337
