Saltar al contenido principal
Motorola i710 LCD Screen Cover Replacement
Qué necesitas
  1. Motorola i710 LCD Screen Cover Replacement, Battery Cover: paso 1, imagen 1 de 2 Motorola i710 LCD Screen Cover Replacement, Battery Cover: paso 1, imagen 2 de 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 LCD Screen Cover Replacement, Battery: paso 2, imagen 1 de 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: paso 3, imagen 1 de 3 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: paso 3, imagen 2 de 3 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: paso 3, imagen 3 de 3
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  4. Motorola i710 LCD Screen Cover Replacement: paso 4, imagen 1 de 2 Motorola i710 LCD Screen Cover Replacement: paso 4, imagen 2 de 2
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  5. Motorola i710 LCD Screen Cover Replacement: paso 5, imagen 1 de 3 Motorola i710 LCD Screen Cover Replacement: paso 5, imagen 2 de 3 Motorola i710 LCD Screen Cover Replacement: paso 5, imagen 3 de 3
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
Conclusión
Carson Meena
Miembro Desde 10/22/12
16 Reputación
5 Guías creadas
Equipo
Clemson, Team 14-2, Benson Fall 2012 Miembro de Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 13
Todo El Tiempo: 385
