Introducción
The side volume button installation guide will require removal of the battery to access the location of the side volume button. This guide can be used to replace damaged volume buttons.
Partes
No se requieren partes.
Place thumb on the rubber tab on the lower back of the phone.
  • Place thumb on the rubber tab on the lower back of the phone.
  • Push away from the phone to release back panel.
Agregar Comentario
Lift the back panel of the phone to expose battery (not shown here).
  • Lift the back panel of the phone to expose battery (not shown here).
Agregar Comentario
Pull antenna up, away from the phone, to reveal two of six screws.
  • Pull antenna up, away from the phone, to reveal two of six screws.
Agregar Comentario
Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
Agregar Comentario
Gently separate the front and back sides of the phone. Be careful not to break or bend the ribbon cables.
  • Gently separate the front and back sides of the phone.
  • Be careful not to break or bend the ribbon cables.
Agregar Comentario
Detach the first ribbon cable by unplugging it from the logic board. Detach the first ribbon cable by unplugging it from the logic board.
  • Detach the first ribbon cable by unplugging it from the logic board.
Agregar Comentario
Gently remove the side button by pulling the buttons away from the phone. Gently remove the side button by pulling the buttons away from the phone. Gently remove the side button by pulling the buttons away from the phone.
  • Gently remove the side button by pulling the buttons away from the phone.
Agregar Comentario
Conclusión
Haley S
Miembro Desde 11/03/13
1 Reputación
4 Guías creadas
Equipo
Clemson, Team 13-6, Benson Spring 2013 Miembro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 110
