Saltar al contenido principal
Motorola i560 Screen Replacement
Qué necesitas
  1. Motorola i560 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Screen Replacement: paso 2, imagen 1 de 1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Screen Replacement, Motherboard: paso 3, imagen 1 de 1
    • Pull the antenna up to reveal two of the six screws.
  4. Motorola i560 Screen Replacement: paso 4, imagen 1 de 1
    • Unscrew all six screws on the back side of the phone using a T-6 bit.
  5. Motorola i560 Screen Replacement: paso 5, imagen 1 de 2 Motorola i560 Screen Replacement: paso 5, imagen 2 de 2
    • Gently separate the front and back sides of the phone, as shown in the picture.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Screen Replacement: paso 6, imagen 1 de 2 Motorola i560 Screen Replacement: paso 6, imagen 2 de 2
    • Detach the first ribbon cable by unplugging it from the motherboard.
  7. Motorola i560 Screen Replacement: paso 7, imagen 1 de 2 Motorola i560 Screen Replacement: paso 7, imagen 2 de 2
    • Detach the speaker ribbon cable from the motherboard.
  8. Motorola i560 Screen Replacement: paso 8, imagen 1 de 1
    • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
  9. Motorola i560 Screen Replacement, Keypad: paso 9, imagen 1 de 1
    • Push lightly from the front of the keypad to remove it.
  10. Motorola i560 Screen Replacement, Screen: paso 10, imagen 1 de 2 Motorola i560 Screen Replacement, Screen: paso 10, imagen 2 de 2
    • By applying force, "pop" the screen out of the connecting hinge frame of the phone.
  11. Motorola i560 Screen Replacement: paso 11, imagen 1 de 2 Motorola i560 Screen Replacement: paso 11, imagen 2 de 2
    • Carefully slide the speaker ribbon cable through the slot in the front frame of the phone.
  12. Motorola i560 Screen Replacement: paso 12, imagen 1 de 1
    • After sliding the ribbon cable through the front frame of the phone, the separated screen and phone frame will appear as shown.
Conclusión
Ariel
Miembro Desde 03/11/13
19 Reputación
4 Guías creadas
Equipo
Clemson, Team 13-6, Benson Spring 2013 Miembro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 165
