Introducción
This guide will install the motherboard, which will require removal of the battery and disconnection of the speaker and microphone ribbon cables.
Partes
No se requieren partes.
Place thumb on the rubber tab on the lower back of the phone.
  • Place thumb on the rubber tab on the lower back of the phone.
  • Push away from the phone to release back panel.
Agregar Comentario
Lift the back panel of the phone to expose battery (not shown here).
  • Lift the back panel of the phone to expose battery (not shown here).
Agregar Comentario
  • Pull the antenna up to reveal two of the six screws.
Agregar Comentario
  • Unscrew all six screws on the back side of the phone using a T-6 bit.
Agregar Comentario
  • Gently separate the front and back sides of the phone, as shown in the picture.
  • Be careful not to break or bend the ribbon cables.
Agregar Comentario
  • Detach the first ribbon cable by unplugging it from the motherboard.
Agregar Comentario
  • Detach the speaker ribbon cable from the motherboard.
Agregar Comentario
  • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ariel
Miembro Desde 11/03/13
16 Reputación
6 Guías creadas
Equipo
Clemson, Team 13-6, Benson Spring 2013 Miembro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 86
