Introducción
Removing the speaker requires the removal of the motherboard, which requires nearly a full dis-assembly of the phone.
Partes
No se requieren partes.
Place thumb on the rubber tab on the lower back of the phone.
  • Place thumb on the rubber tab on the lower back of the phone.
  • Push away from the phone to release back panel.
Agregar Comentario
Lift the back panel of the phone to expose battery (not shown here).
  • Lift the back panel of the phone to expose battery (not shown here).
Agregar Comentario
  • Pull antenna up, away from the phone, to reveal two of six screws.
Agregar Comentario
  • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
Agregar Comentario
  • Gently separate the front and back sides of the phone.
  • Be careful not to break or bend the ribbon cables.
Agregar Comentario
  • Detach the first ribbon cable by unplugging it from the logic board.
Agregar Comentario
  • Gently remove the side button by pulling the buttons away from the phone.
Agregar Comentario
  • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
Agregar Comentario
  • Slightly bend the phone frame to expose microphone protrusion.
  • Gently remove microphone using your fingers.
Agregar Comentario
  • Once the microphone has been removed, remove the connecting piece
Agregar Comentario
Conclusión
Haley S
Miembro Desde 11/03/13
1 Reputación
4 Guías creadas
Equipo
Clemson, Team 13-6, Benson Spring 2013 Miembro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 102
