Introducción
The metal support plate must be removed in order to get to the phone speaker for removal.
Partes
No se requieren partes.
Place thumb on the rubber tab on the lower back of the phone.
  • Place thumb on the rubber tab on the lower back of the phone.
  • Push away from the phone to release back panel.
Agregar Comentario
Lift the back panel of the phone to expose battery (not shown here).
  • Lift the back panel of the phone to expose battery (not shown here).
Agregar Comentario
  • Pull antenna up, away from the phone, to reveal two of six screws.
Agregar Comentario
  • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
Agregar Comentario
  • Gently separate the front and back sides of the phone.
  • Be careful not to break or bend the ribbon cables.
Agregar Comentario
  • Detach the first ribbon cable by unplugging it from the logic board.
Agregar Comentario
  • Gently remove the side button by pulling the buttons away from the phone.
Agregar Comentario
  • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
Agregar Comentario
Conclusión
Haley S
Miembro Desde 11/03/13
1 Reputación
4 Guías creadas
Equipo
Clemson, Team 13-6, Benson Spring 2013 Miembro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 88
