Saltar al contenido principal
Motorola i450 Boost Mobile Circuit Board Replacement
Qué necesitas
  1. Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: paso 1, imagen 1 de 3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: paso 1, imagen 2 de 3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: paso 1, imagen 3 de 3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Circuit Board Replacement, Battery: paso 2, imagen 1 de 3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: paso 2, imagen 2 de 3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: paso 2, imagen 3 de 3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: paso 3, imagen 1 de 2 Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: paso 3, imagen 2 de 2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Circuit Board Replacement: paso 4, imagen 1 de 3 Motorola i450 Boost Mobile Circuit Board Replacement: paso 4, imagen 2 de 3 Motorola i450 Boost Mobile Circuit Board Replacement: paso 4, imagen 3 de 3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Circuit Board Replacement, Circuit Board: paso 5, imagen 1 de 1
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Circuit Board Replacement: paso 6, imagen 1 de 1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Circuit Board Replacement: paso 7, imagen 1 de 3 Motorola i450 Boost Mobile Circuit Board Replacement: paso 7, imagen 2 de 3 Motorola i450 Boost Mobile Circuit Board Replacement: paso 7, imagen 3 de 3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
Conclusión
Amber King
Miembro Desde 10/22/12
8 Reputación
2 Guías creadas
Equipo
Clemson, Team 15-2, Benson Fall 2012 Miembro de Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 427
