Introducción
Throughout the use of the cell phone it is common for the keypad to become worn. This guide provides details on how to replace the rubber cover that acts as the phone's keypad interface. Performing this replacement requires little technical knowledge other than how to follow a series of instructions.
Qué necesitas
Push the tab located at the bottom of the battery towards the top of the phone.
Lift the battery away from the phone.
Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
Pull the antenna straight out of the phone.
Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
