Saltar al contenido principal
Motorola i1000plus Back Cover Replacement
Qué necesitas
  1. Motorola i1000plus Back Cover Replacement, Battery: paso 1, imagen 1 de 3 Motorola i1000plus Back Cover Replacement, Battery: paso 1, imagen 2 de 3 Motorola i1000plus Back Cover Replacement, Battery: paso 1, imagen 3 de 3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: paso 2, imagen 1 de 3 Motorola i1000plus Back Cover Replacement, Antenna: paso 2, imagen 2 de 3 Motorola i1000plus Back Cover Replacement, Antenna: paso 2, imagen 3 de 3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: paso 3, imagen 1 de 3 Motorola i1000plus Back Cover Replacement, Back Cover: paso 3, imagen 2 de 3 Motorola i1000plus Back Cover Replacement, Back Cover: paso 3, imagen 3 de 3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: paso 4, imagen 1 de 1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: paso 5, imagen 1 de 1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: paso 6, imagen 1 de 3 Motorola i1000plus Back Cover Replacement: paso 6, imagen 2 de 3 Motorola i1000plus Back Cover Replacement: paso 6, imagen 3 de 3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
Conclusión
Austin Lake
Miembro Desde 10/18/13
501 Reputación
5 Guías creadas
Equipo
Clemson, Team 13-3, Benson Fall 2013 Miembro de Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 200
