Saltar al contenido principal
Motorola Xoom Wifi Back-Facing Camera Replacement
Qué necesitas
  1. Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: paso 1, imagen 1 de 2 Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: paso 1, imagen 2 de 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Back-Facing Camera Replacement: paso 2, imagen 1 de 2 Motorola Xoom Wifi Back-Facing Camera Replacement: paso 2, imagen 2 de 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Back-Facing Camera Replacement: paso 3, imagen 1 de 3 Motorola Xoom Wifi Back-Facing Camera Replacement: paso 3, imagen 2 de 3 Motorola Xoom Wifi Back-Facing Camera Replacement: paso 3, imagen 3 de 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: paso 4, imagen 1 de 2 Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: paso 4, imagen 2 de 2
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  5. Motorola Xoom Wifi Back-Facing Camera Replacement: paso 5, imagen 1 de 2 Motorola Xoom Wifi Back-Facing Camera Replacement: paso 5, imagen 2 de 2
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 3-39, Maness Spring 2014 Miembro de Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 377
