Saltar al contenido principal
Motorola XOOM 2 Media Edition Microphone Replacement
Qué necesitas
  1. Motorola XOOM 2 Media Edition Microphone Replacement, Motorola XOOM 2 Media Edition Disassembly: paso 1, imagen 1 de 2 Motorola XOOM 2 Media Edition Microphone Replacement, Motorola XOOM 2 Media Edition Disassembly: paso 1, imagen 2 de 2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Microphone Replacement: paso 2, imagen 1 de 2 Motorola XOOM 2 Media Edition Microphone Replacement: paso 2, imagen 2 de 2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Microphone Replacement: paso 3, imagen 1 de 3 Motorola XOOM 2 Media Edition Microphone Replacement: paso 3, imagen 2 de 3 Motorola XOOM 2 Media Edition Microphone Replacement: paso 3, imagen 3 de 3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Microphone Replacement, Microphone: paso 4, imagen 1 de 1
    • Gently pull up rubber housing with tweezers from above microphone.
    • There is adhesive holding down the rubber microphone housing.
  5. Motorola XOOM 2 Media Edition Microphone Replacement: paso 5, imagen 1 de 1
    • Using the tweezers, gently pull up the connector off the microphone.
  6. Motorola XOOM 2 Media Edition Microphone Replacement: paso 6, imagen 1 de 2 Motorola XOOM 2 Media Edition Microphone Replacement: paso 6, imagen 2 de 2
    • Once the connector is removed, use the tweezers to pull up the microphone from its plastic socket.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 149
