Saltar al contenido principal
Motorola XOOM 2 Media Edition Battery Replacement
Qué necesitas
  1. Motorola XOOM 2 Media Edition Battery Replacement, Battery: paso 1, imagen 1 de 2 Motorola XOOM 2 Media Edition Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Power off your tablet before beginning disassembly.
    • Remove six 2.74mm Torx #3 screws from the back panel of the device with a Torx T3 screwdriver.
  2. Motorola XOOM 2 Media Edition Battery Replacement: paso 2, imagen 1 de 2 Motorola XOOM 2 Media Edition Battery Replacement: paso 2, imagen 2 de 2
    • There is adhesive attached to the underside of the back panel. Gradually lift panel to avoid bending it out of shape.
    • Pry off the back panel with a plastic opening tool.
  3. Motorola XOOM 2 Media Edition Battery Replacement: paso 3, imagen 1 de 2 Motorola XOOM 2 Media Edition Battery Replacement: paso 3, imagen 2 de 2
    • These screws are tight and prone to becoming stripped.
    • The battery cables are likely to snap when removing the screws.
    • Remove two 2.38mm Torx #5 screws from battery cables with Torx T5 screwdriver.
  4. Motorola XOOM 2 Media Edition Battery Replacement: paso 4, imagen 1 de 3 Motorola XOOM 2 Media Edition Battery Replacement: paso 4, imagen 2 de 3 Motorola XOOM 2 Media Edition Battery Replacement: paso 4, imagen 3 de 3
    • Pull up the battery cables and battery chip with tweezers.
  5. Motorola XOOM 2 Media Edition Battery Replacement: paso 5, imagen 1 de 2 Motorola XOOM 2 Media Edition Battery Replacement: paso 5, imagen 2 de 2
    • Pry the battery out of the device with the plastic opening tool.
    • Some force is needed to lift the battery up because of the adhesive attached to the backside of the battery.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,015
