Saltar al contenido principal
Motorola XOOM 2 Media Edition Back Facing Camera Replacement
Qué necesitas
  1. Motorola XOOM 2 Media Edition Back Facing Camera Replacement, Motorola XOOM 2 Media Edition Disassembly: paso 1, imagen 1 de 2 Motorola XOOM 2 Media Edition Back Facing Camera Replacement, Motorola XOOM 2 Media Edition Disassembly: paso 1, imagen 2 de 2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Back Facing Camera Replacement: paso 2, imagen 1 de 2 Motorola XOOM 2 Media Edition Back Facing Camera Replacement: paso 2, imagen 2 de 2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Back Facing Camera Replacement: paso 3, imagen 1 de 3 Motorola XOOM 2 Media Edition Back Facing Camera Replacement: paso 3, imagen 2 de 3 Motorola XOOM 2 Media Edition Back Facing Camera Replacement: paso 3, imagen 3 de 3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Back Facing Camera Replacement, Back Facing Camera: paso 4, imagen 1 de 1
    • Gently remove the blue tape near the camera using the tweezers.
  5. Motorola XOOM 2 Media Edition Back Facing Camera Replacement: paso 5, imagen 1 de 1
    • Using the tweezers, remove the camera by grabbing the metal and pulling it out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 388
