Saltar al contenido principal
Motorola W490 Battery Replacement
Qué necesitas
  1. Motorola W490 Battery Replacement, Phone Casing: paso 1, imagen 1 de 2 Motorola W490 Battery Replacement, Phone Casing: paso 1, imagen 2 de 2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 Battery Replacement, Battery: paso 2, imagen 1 de 2 Motorola W490 Battery Replacement, Battery: paso 2, imagen 2 de 2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
Conclusión
Hannah
Miembro Desde 10/22/12
1 Reputación
2 Guías creadas
Equipo
Clemson, Team 14-1, Benson Fall 2012 Miembro de Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Miembros
23 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 681
