Saltar al contenido principal
Motorola W385 Top Logic Board Replacement
Qué necesitas
  1. Motorola W385 Top Logic Board Replacement, Battery: paso 1, imagen 1 de 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Top Logic Board Replacement: paso 2, imagen 1 de 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Top Logic Board Replacement, Front Casing: paso 3, imagen 1 de 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Top Logic Board Replacement: paso 4, imagen 1 de 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Top Logic Board Replacement: paso 5, imagen 1 de 2 Motorola W385 Top Logic Board Replacement: paso 5, imagen 2 de 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Top Logic Board Replacement: paso 6, imagen 1 de 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 Top Logic Board Replacement, Top Logic Board: paso 7, imagen 1 de 1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 Top Logic Board Replacement: paso 8, imagen 1 de 3 Motorola W385 Top Logic Board Replacement: paso 8, imagen 2 de 3 Motorola W385 Top Logic Board Replacement: paso 8, imagen 3 de 3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 Top Logic Board Replacement: paso 9, imagen 1 de 3 Motorola W385 Top Logic Board Replacement: paso 9, imagen 2 de 3 Motorola W385 Top Logic Board Replacement: paso 9, imagen 3 de 3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
Conclusión
Javier Mendez
Miembro Desde 01/21/10
13 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-50, Regan Winter 2010 Miembro de Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 2,519
