Saltar al contenido principal
Motorola W385 Logic Board Replacement
Qué necesitas
  1. Motorola W385 Logic Board Replacement, Battery: paso 1, imagen 1 de 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Logic Board Replacement: paso 2, imagen 1 de 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Logic Board Replacement, Bottom Casing: paso 3, imagen 1 de 1
    • Hold the phone as shown in the photo.
  4. Motorola W385 Logic Board Replacement: paso 4, imagen 1 de 2 Motorola W385 Logic Board Replacement: paso 4, imagen 2 de 2
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
  5. Motorola W385 Logic Board Replacement: paso 5, imagen 1 de 1
    • Remove the two Torx-6 screws under the removed plastic.
  6. Motorola W385 Logic Board Replacement: paso 6, imagen 1 de 1
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
  7. Motorola W385 Logic Board Replacement: paso 7, imagen 1 de 3 Motorola W385 Logic Board Replacement: paso 7, imagen 2 de 3 Motorola W385 Logic Board Replacement: paso 7, imagen 3 de 3
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
  8. Motorola W385 Logic Board Replacement: paso 8, imagen 1 de 1
    • The casing can be easily removed exposing the bottom logic board.
  9. Motorola W385 Logic Board Replacement, Main Logic Board: paso 9, imagen 1 de 2 Motorola W385 Logic Board Replacement, Main Logic Board: paso 9, imagen 2 de 2
    • Use spudger to gently separate the ribbon cable from the logic board.
  10. Motorola W385 Logic Board Replacement: paso 10, imagen 1 de 2 Motorola W385 Logic Board Replacement: paso 10, imagen 2 de 2
    • Place the sharp end of the spudger in the hole at the bottom of the logic board.
    • Gently remove the logic board from the phone casing.
    • Make sure not to damage any other components of the logic board.
Conclusión
2 personas más completaron esta guía.
Javier Mendez
Miembro Desde 01/21/10
13 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-50, Regan Winter 2010 Miembro de Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 3,198
