Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Is the plastic casing cracked or severely scratched? Replace it.
  1. Using your finger, press down on the clip holding the back cover on.
    • Using your finger, press down on the clip holding the back cover on.
  2. Using the spudger or your finger, gently pull the battery out from the top.
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Hold the phone as shown in the photo.
    • Hold the phone as shown in the photo.
  4. Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center. This might require a little persistence due how the beveled plastic rests on the phone body.
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
  5. Remove the two Torx-6 screws under the removed plastic.
    • Remove the two Torx-6 screws under the removed plastic.
  6. Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
  7. Hold the phone with the keys facing down and the mini USB charging port visible. Open the rubber flap covering the charging port. Insert the flat end of the spudger just above the charging port.
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
  8. The casing can be easily removed exposing the bottom logic board.
    • The casing can be easily removed exposing the bottom logic board.
Conclusión
Austin Hobbs
Miembro Desde 21/01/10
30 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 8-50, Regan Winter 2010 Miembro de Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,309
