Saltar al contenido principal
Motorola W315 Circuit Board Replacement
Qué necesitas
  1. Motorola W315 Circuit Board Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Circuit Board Replacement: paso 3, imagen 1 de 1
    • Insert the new battery.
  3. Motorola W315 Circuit Board Replacement, Rear Case: paso 4, imagen 1 de 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Circuit Board Replacement: paso 5, imagen 1 de 3 Motorola W315 Circuit Board Replacement: paso 5, imagen 2 de 3 Motorola W315 Circuit Board Replacement: paso 5, imagen 3 de 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Circuit Board Replacement, Circuit Board: paso 6, imagen 1 de 3 Motorola W315 Circuit Board Replacement, Circuit Board: paso 6, imagen 2 de 3 Motorola W315 Circuit Board Replacement, Circuit Board: paso 6, imagen 3 de 3
    • Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
  6. Motorola W315 Circuit Board Replacement: paso 7, imagen 1 de 3 Motorola W315 Circuit Board Replacement: paso 7, imagen 2 de 3 Motorola W315 Circuit Board Replacement: paso 7, imagen 3 de 3
    • Use the plastic opening tool to remove the chip connected by magnetic strip to the screen.
    • Remove circuit board.
Conclusión
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
Miembro Desde 03/26/14
399 Reputación
4 Guías creadas
Equipo
Clemson, Team 6-3, Benson Spring 2014 Miembro de Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 197
