Saltar al contenido principal
Motorola V710 Speaker Replacement
Qué necesitas
  1. Motorola V710 Speaker Replacement, Battery: paso 1, imagen 1 de 3 Motorola V710 Speaker Replacement, Battery: paso 1, imagen 2 de 3 Motorola V710 Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Speaker Replacement: paso 2, imagen 1 de 3 Motorola V710 Speaker Replacement: paso 2, imagen 2 de 3 Motorola V710 Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Speaker Replacement, Logic Board: paso 3, imagen 1 de 2 Motorola V710 Speaker Replacement, Logic Board: paso 3, imagen 2 de 2
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Speaker Replacement: paso 4, imagen 1 de 2 Motorola V710 Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Speaker Replacement: paso 5, imagen 1 de 3 Motorola V710 Speaker Replacement: paso 5, imagen 2 de 3 Motorola V710 Speaker Replacement: paso 5, imagen 3 de 3
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Speaker Replacement: paso 6, imagen 1 de 2 Motorola V710 Speaker Replacement: paso 6, imagen 2 de 2
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Speaker Replacement: paso 7, imagen 1 de 2 Motorola V710 Speaker Replacement: paso 7, imagen 2 de 2
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Speaker Replacement: paso 8, imagen 1 de 3 Motorola V710 Speaker Replacement: paso 8, imagen 2 de 3 Motorola V710 Speaker Replacement: paso 8, imagen 3 de 3
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Speaker Replacement: paso 9, imagen 1 de 1
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Speaker Replacement: paso 10, imagen 1 de 2 Motorola V710 Speaker Replacement: paso 10, imagen 2 de 2
    • Remove the logic board.
  11. Motorola V710 Speaker Replacement, Replacing Speaker: paso 11, imagen 1 de 2 Motorola V710 Speaker Replacement, Replacing Speaker: paso 11, imagen 2 de 2
    • Use the spudger take the speaker out.
Conclusión
Karl Sanders
Miembro Desde 01/26/10
8 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-49, Regan Winter 2010 Miembro de Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,035
