Saltar al contenido principal
Motorola V710 LCD screen replacement
Qué necesitas
  1. Motorola V710 LCD screen replacement, Screen: paso 1, imagen 1 de 3 Motorola V710 LCD screen replacement, Screen: paso 1, imagen 2 de 3 Motorola V710 LCD screen replacement, Screen: paso 1, imagen 3 de 3
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
  2. Motorola V710 LCD screen replacement: paso 2, imagen 1 de 2 Motorola V710 LCD screen replacement: paso 2, imagen 2 de 2
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
  3. Motorola V710 LCD screen replacement: paso 3, imagen 1 de 2 Motorola V710 LCD screen replacement: paso 3, imagen 2 de 2
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
  4. Motorola V710 LCD screen replacement: paso 4, imagen 1 de 2 Motorola V710 LCD screen replacement: paso 4, imagen 2 de 2
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
  5. Motorola V710 LCD screen replacement: paso 5, imagen 1 de 2 Motorola V710 LCD screen replacement: paso 5, imagen 2 de 2
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
  6. Motorola V710 LCD screen replacement: paso 6, imagen 1 de 2 Motorola V710 LCD screen replacement: paso 6, imagen 2 de 2
    • Use the spudger to remove the screen.
Conclusión
Equipo
Cal Poly, Team 8-49, Regan Winter 2010 Miembro de Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 2,067
