Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will help show you how to replace the keypad.
Partes
No se especificaron partes.
  1. Press down on the back button while pulling away from the body of the phone to release the back cover. Press down on the back button while pulling away from the body of the phone to release the back cover. Press down on the back button while pulling away from the body of the phone to release the back cover.
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Remove the battery from the phone by gently pulling upward on the battery with your fingers. Remove the battery from the phone by gently pulling upward on the battery with your fingers. Remove the battery from the phone by gently pulling upward on the battery with your fingers.
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Unscrew the antenna with a clockwise motion and pull to remove the antenna.
    • Unscrew the antenna with a clockwise motion and pull to remove the antenna.
  4. Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver. Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver.
    • Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver.
  5. Use the spudger to remove the bottom plate. Use the spudger to remove the bottom plate.
    • Use the spudger to remove the bottom plate.
  6. Unscrew the bottom two screws with the T6 screwdriver. Unscrew the bottom two screws with the T6 screwdriver.
    • Unscrew the bottom two screws with the T6 screwdriver.
  7. Use the spudger to remove the keyboard plate. Use the spudger to remove the keyboard plate.
    • Use the spudger to remove the keyboard plate.
  8. Use your fingers to push out the keyboard.
    • Use your fingers to push out the keyboard.
Linea de Meta
Karl Sanders
Miembro Desde 26/01/10
8 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-49, Regan Winter 2010 Miembro de Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,903
