Saltar al contenido principal
Motorola V60s Speakers Replacement
Qué necesitas
  1. Motorola V60s Speakers Replacement, Battery: paso 1, imagen 1 de 3 Motorola V60s Speakers Replacement, Battery: paso 1, imagen 2 de 3 Motorola V60s Speakers Replacement, Battery: paso 1, imagen 3 de 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Speakers Replacement: paso 2, imagen 1 de 2 Motorola V60s Speakers Replacement: paso 2, imagen 2 de 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Speakers Replacement, Speakers: paso 3, imagen 1 de 2 Motorola V60s Speakers Replacement, Speakers: paso 3, imagen 2 de 2
    • Remove the four screws using a T6 Torx screwdriver.
    • Top screws are silver and short while bottom screws are black and longer.
  4. Motorola V60s Speakers Replacement: paso 4, imagen 1 de 2 Motorola V60s Speakers Replacement: paso 4, imagen 2 de 2
    • Insert an iFixit opening tool into phone in between back panel and body of phone.
    • Carefully pry up until back panel comes off, then remove with hands and set aside.
  5. Motorola V60s Speakers Replacement: paso 5, imagen 1 de 1
    • Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
    • Be careful on this step; it may take some time.
Conclusión
Eric Freeman
Miembro Desde 01/26/10
10 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-48, Regan Winter 2010 Miembro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 1,558
