Saltar al contenido principal
Motorola V60s Button Key Board Replacement
Qué necesitas
  1. Motorola V60s Button Key Board Replacement, Battery: paso 1, imagen 1 de 3 Motorola V60s Button Key Board Replacement, Battery: paso 1, imagen 2 de 3 Motorola V60s Button Key Board Replacement, Battery: paso 1, imagen 3 de 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Button Key Board Replacement: paso 2, imagen 1 de 2 Motorola V60s Button Key Board Replacement: paso 2, imagen 2 de 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Button Key Board Replacement, Logic Board: paso 3, imagen 1 de 2 Motorola V60s Button Key Board Replacement, Logic Board: paso 3, imagen 2 de 2
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Button Key Board Replacement: paso 4, imagen 1 de 3 Motorola V60s Button Key Board Replacement: paso 4, imagen 2 de 3 Motorola V60s Button Key Board Replacement: paso 4, imagen 3 de 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Button Key Board Replacement: paso 5, imagen 1 de 3 Motorola V60s Button Key Board Replacement: paso 5, imagen 2 de 3 Motorola V60s Button Key Board Replacement: paso 5, imagen 3 de 3
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Button Key Board Replacement: paso 6, imagen 1 de 3 Motorola V60s Button Key Board Replacement: paso 6, imagen 2 de 3 Motorola V60s Button Key Board Replacement: paso 6, imagen 3 de 3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Button Key Board Replacement: paso 7, imagen 1 de 2 Motorola V60s Button Key Board Replacement: paso 7, imagen 2 de 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
  8. Motorola V60s Button Key Board Replacement, Button Key Board: paso 8, imagen 1 de 2 Motorola V60s Button Key Board Replacement, Button Key Board: paso 8, imagen 2 de 2
    • Insert spudger under button board and gently lift, set aside.
Conclusión
Eric Freeman
Miembro Desde 01/26/10
10 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-48, Regan Winter 2010 Miembro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,335
