Saltar al contenido principal
Motorola V60s Battery Replacement
Qué necesitas
  1. Motorola V60s Battery Replacement, Battery: paso 1, imagen 1 de 3 Motorola V60s Battery Replacement, Battery: paso 1, imagen 2 de 3 Motorola V60s Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Battery Replacement: paso 2, imagen 1 de 2 Motorola V60s Battery Replacement: paso 2, imagen 2 de 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
Conclusión
Eric Freeman
Miembro Desde 01/26/10
10 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-48, Regan Winter 2010 Miembro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,720
