Saltar al contenido principal
Motorola V60i Keypad Sensor Replacement
Qué necesitas
  1. Motorola V60i Keypad Sensor Replacement, Battery: paso 1, imagen 1 de 2 Motorola V60i Keypad Sensor Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Keypad Sensor Replacement: paso 2, imagen 1 de 2 Motorola V60i Keypad Sensor Replacement: paso 2, imagen 2 de 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Keypad Sensor Replacement, Back Plate: paso 3, imagen 1 de 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Keypad Sensor Replacement: paso 4, imagen 1 de 2 Motorola V60i Keypad Sensor Replacement: paso 4, imagen 2 de 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Keypad Sensor Replacement: paso 5, imagen 1 de 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Motorola V60i Keypad Sensor Replacement, Motherboard: paso 6, imagen 1 de 1
    • Gently lift logic board from back plate.
  7. Motorola V60i Keypad Sensor Replacement: paso 7, imagen 1 de 2 Motorola V60i Keypad Sensor Replacement: paso 7, imagen 2 de 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
  8. Motorola V60i Keypad Sensor Replacement, Keypad Sensor: paso 8, imagen 1 de 2 Motorola V60i Keypad Sensor Replacement, Keypad Sensor: paso 8, imagen 2 de 2
    • Once logic board is removed lift the green keypad sensor for the front plate.
Conclusión
Equipo
Cal Poly, Team 30-40, Garner Spring 2010 Miembro de Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Miembros
19 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 2,020
