Saltar al contenido principal
Motorola V60i Back Plate Replacement
Qué necesitas
  1. Motorola V60i Back Plate Replacement, Battery: paso 1, imagen 1 de 2 Motorola V60i Back Plate Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Back Plate Replacement: paso 2, imagen 1 de 2 Motorola V60i Back Plate Replacement: paso 2, imagen 2 de 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Back Plate Replacement, Back Plate: paso 3, imagen 1 de 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Back Plate Replacement: paso 4, imagen 1 de 2 Motorola V60i Back Plate Replacement: paso 4, imagen 2 de 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Back Plate Replacement: paso 5, imagen 1 de 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
Conclusión
Equipo
Cal Poly, Team 30-40, Garner Spring 2010 Miembro de Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 14
Todo El Tiempo: 3,576
