Saltar al contenido principal
Motorola V60c Side Buttons Replacement
Qué necesitas
  1. Motorola V60c Side Buttons Replacement, Battery: paso 1, imagen 1 de 2 Motorola V60c Side Buttons Replacement, Battery: paso 1, imagen 2 de 2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Side Buttons Replacement: paso 2, imagen 1 de 2 Motorola V60c Side Buttons Replacement: paso 2, imagen 2 de 2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Side Buttons Replacement, Side Buttons: paso 3, imagen 1 de 1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Side Buttons Replacement: paso 4, imagen 1 de 2 Motorola V60c Side Buttons Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pry up back cover from two side clips.
    • NOTE: sticker might be attached to rest of phone.
  5. Motorola V60c Side Buttons Replacement: paso 5, imagen 1 de 1
    • Remove the back cover.
  6. Motorola V60c Side Buttons Replacement: paso 6, imagen 1 de 2 Motorola V60c Side Buttons Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Side Buttons Replacement: paso 7, imagen 1 de 2 Motorola V60c Side Buttons Replacement: paso 7, imagen 2 de 2
    • Carefully flip over main logic board.
    • Remove rubber side buttons.
Conclusión
Ryan Kuroiwa
Miembro Desde 04/10/10
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-86, Amido Spring 2010 Miembro de Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 5,183
