Introducción
How to replace the logic board.
  1. Depress the silver button.
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Hold battery from both sides at the bottom.
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
    • Use a plastic opening tool to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
    • Remove the back cover.
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board to remove.
Conclusión
Ryan Kuroiwa
Miembro Desde 10/04/10
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-86, Amido Spring 2010 Miembro de Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Miembros
10 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,245
