Introducción
How to replace a faulty antenna.
  1. Depress the silver button. Pull from top of phone to lift the cover.
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Hold battery from both sides at the bottom. Push upwards and gently lift to remove.
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Remove the four screws from the corners using a T-6 screwdriver.
    • Remove the four screws from the corners using a T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  5. Use spudger to pry up back cover from the two side clips. NOTE: sticker might be attached to rest of phone.
    • Use spudger to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
  6. Flip over the back cover. Remove the plastic frame. Remove the plastic frame.
    • Flip over the back cover.
    • Remove the plastic frame.
  7. Lift up antenna. Lift up antenna.
    • Lift up antenna.
Conclusión
Ryan Kuroiwa
Miembro Desde 10/04/10
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-86, Amido Spring 2010 Miembro de Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Miembros
10 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,691
