Saltar al contenido principal
Motorola V557 Rear Casing Replacement
Qué necesitas
  1. Motorola V557 Rear Casing Replacement, Battery: paso 1, imagen 1 de 3 Motorola V557 Rear Casing Replacement, Battery: paso 1, imagen 2 de 3 Motorola V557 Rear Casing Replacement, Battery: paso 1, imagen 3 de 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Rear Casing Replacement: paso 2, imagen 1 de 2 Motorola V557 Rear Casing Replacement: paso 2, imagen 2 de 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Rear Casing Replacement, SIM Card: paso 3, imagen 1 de 3 Motorola V557 Rear Casing Replacement, SIM Card: paso 3, imagen 2 de 3 Motorola V557 Rear Casing Replacement, SIM Card: paso 3, imagen 3 de 3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Rear Casing Replacement, Antenna: paso 4, imagen 1 de 2 Motorola V557 Rear Casing Replacement, Antenna: paso 4, imagen 2 de 2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Rear Casing Replacement, Rear Casing: paso 5, imagen 1 de 3 Motorola V557 Rear Casing Replacement, Rear Casing: paso 5, imagen 2 de 3 Motorola V557 Rear Casing Replacement, Rear Casing: paso 5, imagen 3 de 3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Rear Casing Replacement: paso 6, imagen 1 de 3 Motorola V557 Rear Casing Replacement: paso 6, imagen 2 de 3 Motorola V557 Rear Casing Replacement: paso 6, imagen 3 de 3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Rear Casing Replacement: paso 7, imagen 1 de 3 Motorola V557 Rear Casing Replacement: paso 7, imagen 2 de 3 Motorola V557 Rear Casing Replacement: paso 7, imagen 3 de 3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
Conclusión
Alex Georges
Miembro Desde 10/02/10
40 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-50, Amido Fall 2010 Miembro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,360
