Introducción
This section will show how to separate the pieces of the main case to reveal the internal components.
Herramientas
Partes
No se especificaron partes.
Push down on the silver button while sliding the back plate down to reveal the battery.
Move the the metal slider towards the top of the phone until it clicks out of its original position.
Slide out and remove the SIM card.
Grip the antenna and twist it counterclockwise to loosen it.
When it has been loosened all the way, pull gently to remove the antenna piece.
Remove the screw covers over the two top screws by prying gently with a pin.
The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
